no1clipsmyclaws 1985 4Runner Build-Up Thread
Old Dec 2, 2011 | 05:43 PM
dropzone's Avatar
Fossilized
Originally Posted by no1clipsmyclaws
This is what caused my 2 tires to pop previously. While offroading the front tire digs into the back of the front fender/firewall area.
Also, my tire is pretty much rubbing on the front of my rock slider. So that sucks.
If you are running High steer (don't remember if you are) quick fix that would help a little would be to redrill the front spring perch and move the axle forward an inch or so..I need to do the same thing on mine..
edit--never mind..just saw you have the stock push pull steering...
Old Dec 2, 2011 | 06:42 PM
jswizz's Avatar
Very nice looking runner , and with alot of mods Already . Keep it up , your pics help keep motivated . my 33's also rub and smashed that seam also .your lifted more though.
85 SR 5 4RUNNER 33x12x50 ,leveled , new tie rods front bearings
fixed dome lights ,
Old Dec 17, 2011 | 03:14 PM
no1clipsmyclaws's Avatar
Old Dec 17, 2011 | 05:20 PM
775Toy's Avatar
Good find. Your runner looks great. Keep up the good work.
Old Feb 11, 2012 | 08:40 AM
  #25
liveoffroad's Avatar
Originally Posted by racehoss
I've got the same problem with my tires hitting that area.
Solution is get a new hanger for the front of the springs that moves the axle forward a bit or I've got a buddy that used axle relocation plates from allprooffroad.com and that move it forward without welding.
had the same problem when i was running 33x12.50s. I did a cheap fix by taking the springs off and having a shop drill some new center holes about 3/4" forward. (i tried drilling them myself at first but they ain't kiddin' when they call it "hardened steel"). 3/4" wasn't enough to mess with the stock steering configuration but got me more than enough clearance to stuff my 33s!
Your truck's lookin good, i like your interior work, i'm getting ready to do some of that myself.
Old Mar 10, 2012 | 10:30 PM
  #26
Old Mar 11, 2012 | 04:09 AM
  #27
ToyBoy Twink's Avatar
Hey there no1clipsmyclaws, that really sucks about your Toy. Looked like it was real clean to start with. U could cut the top off and put a full cage in. At least the roof wouldn't b dented anymore. Lol, jk. Good luck with it and keep the updates coming.
Old Mar 11, 2012 | 05:38 AM
  #28
Old Mar 11, 2012 | 08:13 AM
  #29
775Toy's Avatar
Cut top off and go cage with soft top, and continue to raisin your body. Battle scars.
Old Mar 12, 2012 | 08:18 AM
  #30
Outsane's Avatar
good to see you kept truckin...
I got a replacement roof for about $150 after I flopped...and it was pretty easy weld on
Old Mar 12, 2012 | 12:01 PM
  #31
Old Mar 12, 2012 | 12:44 PM
  #32
Outsane's Avatar
get the best one you can afford and plan to use!
I ended up getting a sunroof I didn't have before the flop!
Old Mar 19, 2012 | 11:19 AM
  #33
dang, thats a knarly flip. you did an awesome job getting it back in order!
Old Mar 19, 2012 | 11:40 AM
  #34
Old Mar 27, 2012 | 03:12 PM
  #35
Outsane's Avatar
https://www.yotatech.com/forums/f115/roof-swap-177146/
roof swap thread!
SpecialScottie
142
Oct 23, 2013 01:13 PM
1985runner
Jul 14, 2011 02:04 AM
my85runner
Sep 2, 2005 03:21 AM
