| Jfixedit |
Mar 13, 2023 12:02 PM |
85 XtraCab Hard Fuel Lines
I tried searching for an answer but couldn't find one. Restoring an 85 XtraCab 4wd painted Army Green to match my 22 Tacoma. I'm down to the fuel hard lines. There's 2 (vent and return) that run under the cab. The pressure line runs with the brake lines along the PS frame rail. I planned on replacing all 3 with new 3/8" steel brake line. Is there a reason why Toyota ran the lines separate from each other? Could I run all 3 lines in parallel with each other either along the frame rail or under the cab? Is there a better way to do this? I have the old lines for a template and am proficient with a bender.
