1985 4Runner
Old 03-30-2018, 01:16 PM
JohnnyCanuck's Avatar
Like most 1st Gen 4Runners, the rear window is sloooow up and down. I took it apart, the tracks/guides look good, no broken teeth. I noticed it was a reman motor so it’s been replaced at some time. I took it apart, cleaned up the brushes etc, lubed everything up and it made no difference. I’m going to snag a Toyota motor from the auto wreckers, apparently the left side motor from any Toyota of the same era will work.
I cleaned the inside windows, laid the seats down just because, and found a Toyota pouch with odds and ends, the jack is behind the lh panel.
Old 03-30-2018, 01:34 PM
RAD4Runner's Avatar
Hi Johnny,
Curious where u got your swing-out tire carrier.
Originally Posted by JohnnyCanuck
... laid the seats down just because...
I removed my rear seat bottoms because I seldom have passengers there, they do not clear my head when sleeping there, and those things weigh 15 pounds each! Then, found a "roll-out memory foam lounger" at Costco. Almost perfect fit (just an inch too narrow) between the wheel-wells. The 1-inch thick firm, white foam is what I use as "bench" pads for rear seat bottoms when I have passengers in the back and double as extra cushion layer for sleeping
Old 03-30-2018, 02:28 PM
Hi Johnny,
https://youtu.be/100e7wG7rEE
the tire carrier is from a pathfinder, PO used plates inside the body panels to mount them, the foam you used is perfect, and I agree, I’ll have to do the same as you and remove the bottoms as I’ll need that room to stretch out.
Old 03-30-2018, 03:39 PM
Pics of carrier, there are plates inside the body panel that bolt to the carrier.
Attached Thumbnails 1985 4Runner-422f16e2-f5a8-4422-b143-ced2fe68aec0.jpg   1985 4Runner-c99149b4-8e7b-4548-9dec-e725a8b53e5b.jpg
Old 04-20-2018, 06:00 AM
  #25
Sold due to medical reasons.
Old 04-20-2018, 06:38 AM
  #26
RAD4Runner's Avatar
I hope that all will be alright, Johnny.
stranded1980
17
07-08-2018 07:10 PM
redhanded
07-30-2011 12:24 PM
GRM
01-28-2007 11:01 AM
Quick Reply: 1985 4Runner
