YotaTech Forums
-   84-85 Trucks & 4Runners (Build-Up Section) (https://www.yotatech.com/forums/f198/)
-   -   1967 Stout body swap (https://www.yotatech.com/forums/f198/1967-stout-body-swap-314430/)
Stoutguy Nov 1, 2021 03:37 PM
Started swapping my 67 Stout body onto an 85 Hilux 4x. If anyone else has done this, I’d sure like to hear from you.
Melrose 4r Nov 2, 2021 02:45 PM
Sounds great! I hope you share photos.
Stoutguy Nov 2, 2021 02:54 PM
Photos coming
A few pics. The body fits fairly closely to the 85. The radiator to fan clearance looks like it will be the biggest issue. Once the body to frame mounts are fabbed, and things aren’t moving around, I’ll start working on the core support.
https://cimg6.ibsrv.net/gimg/www.yot...b40b1394b.jpeg
Tear down of 67
https://cimg7.ibsrv.net/gimg/www.yot...83c58d70e.jpeg
More tear down
https://cimg8.ibsrv.net/gimg/www.yot...4ed802548.jpeg
From the back
https://cimg9.ibsrv.net/gimg/www.yot...b1324980f.jpeg
Initial bed mock-up on 85 frame
https://cimg0.ibsrv.net/gimg/www.yot...43121818e.jpeg
Left side of bed
https://cimg1.ibsrv.net/gimg/www.yot...7ce9e9a66.jpeg
Initial cab mock-up
https://cimg2.ibsrv.net/gimg/www.yot...66d2ac9fc.jpeg
Lining up cab and bed
https://cimg3.ibsrv.net/gimg/www.yot...1e87229b8.jpeg
Interior alignment
https://cimg4.ibsrv.net/gimg/www.yot...736aa17b2.jpeg
Firewall clearance
https://cimg8.ibsrv.net/gimg/www.yot...f02ad9acd.jpeg
Most lines matching up and ready to fab frame mounts.
https://cimg7.ibsrv.net/gimg/www.yot...dce8d47a5.jpeg
Right corner view
BigBluePile Nov 2, 2021 04:00 PM
Sweet!!!
Melrose 4r Nov 2, 2021 05:36 PM
So cool!
maco35 Nov 15, 2021 10:15 PM
Really cool.
Stoutguy Nov 29, 2021 08:18 PM
Body swap update
https://cimg4.ibsrv.net/gimg/www.yot...2f1732121.jpeg
This says it all.
https://cimg5.ibsrv.net/gimg/www.yot...c7808ddeb.jpeg
Core support mount
https://cimg6.ibsrv.net/gimg/www.yot...657590399.jpeg
Core support
https://cimg7.ibsrv.net/gimg/www.yot...273ec7f7b.jpeg
Front cab mount
https://cimg8.ibsrv.net/gimg/www.yot...7f72cc9b4.jpeg
Front cab mount
Finished mock up of bed mounts, front cab mounts, and core support mount. Need to remove the bed to fab the rear cab mounts.
I need to mock up the brake booster and then set the steering column angle at the firewall next.
Still looks like the radiator and fan will be a challenge.
Finished mock up of the brake booster and clutch master. Also got the radiator mounts fabbed. Steering column is next. Looks like I’ll need to splice the steering shaft in order to use the 67 steering wheel on the 85 shaft.
https://cimg6.ibsrv.net/gimg/www.yot...20394afbf.jpeg
Top view of aluminum spacers
https://cimg9.ibsrv.net/gimg/www.yot...3a018fdd7.jpeg
Front view of booster and clutch master
