Which Replacement Alternator 1983 4X4
Greetings Fellow Toyota Enthusiasts,
I'd greatly appreciate some help determining which replacement alternator (and regulator) would work best for my 1983 4X4 Pickup. Battery isn't charging and truck shuts off when one of the terminals is disconnected, so am assuming replacing the battery cables, alternator, and regulator is the first logical step for an engine with 215K miles.
Two different types are showing up in my research (40 amp version and a 55 amp) but I'm
not sure which one to order. Will either one work?
Thank you.
Thank you.
The following users liked this post:
musician235 (09-07-2018)
Thanks for the tip on this; I'm learning more about these more powerful alternators, but the CS-120 is showing only to fit post 1985 vehicles and there was no option for a pre-1985. I called that company and the person wasn't knowledgeable as to whether it would fit an 83 22R or not.
Any idea as to an alternative that would fit? I see there is a mounting bracket kit available to adapt other alternators but before going that route, was hoping for a plug and play situation, maybe a little too easy.
Thanks again.
Thanks again.
If you can live with some down time, I'd take the alternator out and go have it tested at store. And if bad, there's only a couple things in there to go bad. Brushes and rectifier. Brushes are only a couple bucks. Some years of FSM have steps for testing alternator parts with meter, so you can check rectifier. The regulator takes a bit more work but can be tested. There is good chance your brushes are just worn.
musician235 (09-15-2018)
Thanks again.
Thanks again.
tRod
06-15-2013 12:42 PM
'79 beagle hauler
09-12-2010 06:06 PM
mattk
06-13-2004 06:27 AM
