1983 toyota pickup 4x4
#142
Thanks guys, it was between these and the General Grabbers but I know you cant go wrong with the Ko2 so i went the safe route. They did really good in the mud and the ride feels so much better then my old km2s
#143
A current status on the pickup:
The carburetor was acting up and a shop determined that it need a carb rebuild and a new intake gasket. I got quoted around 700 for the carb rebuild/intake gasket as well as a valve adjustment (of course parts as well). I was not going to pay that much and felt confident that I could do the job myself now that I know what the issue is.
This past weekend I got the carburetor off and close to pulling the intake.
#144
The first issue I am already seeing is the gasket that came with my Carb rebuild kit from NAPA. I noticed that the gasket I got that goes between the intake and insulator does not match the design of the insulator.
Here is a pic of the gasket I am referring to that I received from NAPA
Below is what my insulator looks like and what I believe the correct gasket should be.
I am trying to see if I can purchase this gasket separately from toyota but do not see it anywhere. I found the part number to the insulator but I do not know why there is no gasket for it. I believe I read on another thread that the insulator had a gasket already attached but I do not know how true that is.
Does anyone know if I can purchase this gasket on its own? I am thinking about ordering the insulator from Toyota since it is around 30 dollars and just hope it does have the gasket.
#145
The photos look great! Thanks for sharing!
As far as I know, the original gaskets were bonded to the insulator and were one unit. You might be able to see a thin layer on the top of the insulator that is part of the original gasket. It is very hard to see.
The carburetor rebuild kit I got from Autozone had both types of gaskets you show. I haven't seen that gasket separately myself.
#146
#147
I received the new insulator that I ordered and was able to confirm that it does come with the gasket on both sides. I do not need to worry about finding that individual gasket anymore.
#148
Just some more pics of my progress.
Rebuilt the carburetor (won't know how that went till i fire it up lol). Removed the intake completely and cleaned it up ( no pics of how it looks after yet).
The following users liked this post:
faber (11-27-2020)
#150
The block is nice and dirty from all that fun I had in the Mud haha but i will make sure to clean it up
#153
Cleaned up the block a tad bit per Mikes request
I also decided to resurface the intake manifold myself instead of taking it to a machine shop. I purchased a piece of laminate wood from Home Depot and some sand Paper and the results came out great. I got the idea from someone I follow on instagram.
I screwed the wood down to my bench so it wouldnt move and used adhesive spray to stick the sand paper to it.
Here is the Final result.
faber (11-27-2020)
#155
Mike, I also decided to replace the gasket underneath like you mentioned. To be honest, I already had the gasket the entire time I was just fearful of doing it and you will read why below
What i expected would happened ended up happening and I broke 3 of the bolts. A buddy of mine took the intake to a shop he knows to try and get them out. I will post an update when i get it back.
These are the 3 bolts that snapped right off.
faber (11-27-2020)
#157
The best technique to remove broken bolts...
#158
https://www.youtube.com/watch?v=aRrz-cphBY4
#159
Look what I got here. I got the intake back and they were able to remove all three bolts without damaging anything
I also got a new set of tools and I must say I never thought id be so excited for new tools haha will finally be able to clean up some threads
faber (11-27-2020)
#160
I went to a local hardware store who carries every bolt you can think of and they recommended these bolts below for my intake because of the heat. I'm just curious why the bolts are black and if I should really use these for the intake manifold? Not really worried about the color but I think people usually use zinc plated right? They are both labeled 10.9
