1983 toyota pickup 4x4
Thanks Youngiam and dropzone.
Since i changed out my brake lines I need to bleed my brakes. Since i have never done this before i started looking it up on yotatech what order to do so. From what i understand it should be DR, PR, PF, DF and last the LSPV. However, my FSM gives no explanation on how to bleed the LSPV and i do not see a bleeder plug on it. On other threads i have found people have a bleeder plug to the right but mine does not. Do i just crack open one of the fittings? I do appreciate any help.
This is all of the explanation the manual gives on how to bleed the brakes. After step 4 on the bottom the next page goes to talking about the master cylinder.
#26
Besides bleeding the brakes, another question i have is regarding the power steering pump. I rebuilt the one i have but now that i am finishing up on my power steering conversion i realized i am missing one tiny part. It is called the union seat and sits outside the union pressure port. I do not have this part and called Toyota and they said it is discontinued. Is my only option going to a pick a part and finding one there? Is there another part number i can cross reference from a different year. I am so close to finishing the power steering
The part i am talking about is on the bottom right with the arrow pointing to it.
#28
#32
Did you try parts.toyota.com?? They give new part numbers if they have changed. I would think it should still be made.
Maybe you have an old style lspv valve that does not have a bleeder? What does it say in the fsm? Maybe the nut on top is the bleeder?
My instagram is crizzut
#33
#36
Wow, that is pretty ugly looking, can't wait to see mine
How many times did you have to bleed the lines to get fresh fluid coming out?
My LSPV has a screw on it and that's what it says to use for bleeding not a regular bleeder valve, 84 vs 83 so not sure what you have.I'll take a pic when it warms up a bit.
#37
#40
Wow..
