1979 Turbo Diesel 4x4 Pick up build
Originally the truck had a radiator in the tool box. I pulled the fans and radiator. You will see some of the pictures show a flat aluminum cover instead of the vent "scoop". I put a v6 radiator up front when I got the truck. Once I tested the cooling system, I put the flat cover on the toolbox so I could use it as storage.
