need Tacoma rear axle shaft driver ABS
I need a tacoma driver side rear axle shaft with ABS, and with the park brake armature in the verticle (up by the bleeder valve) position. I have the passenger side from an 02. Thanks in advance.
Lots of money on shipping one of those things. Pretty heavy and oblong shape
I have a rear axle from a '99 4Runner w/ABS. The bearings need to be redone, but the rest of it is there. |
Is the park brake armature in the verticle postition, or horizontal? I have a 4Runner that has the latter, and rocks keep tweeking the bracketry because it hangs so low on the axle :cry: . I really only need the driver shaft, but will make exceptions if necessary.
Never mind, I'm going full float and discs!!!!
