Detroit TRu- Trac locker For 8 inch PLEASE DELETE IT SOLD
i have had it for like to 3 years now but my truck was turn in to a trail rig only about a year and a half ago so now im steping up to a spool and need to sell this.it work just fine never been hard on it. im a go slow don't trash my truck kind of wheeler. Im asking 125$ obo will ship on your dime located in denver Colorado. will get on requests. my number 720-936-9015 if you have any questions thanks for looking .PLEASE DELETE THIS IS SOLD ALL READY
shippping to 21701
I'm interestd in shipping to 95842. Thanks, Vince
Interested, but to my knowledge, the front and rear Detroit Truetrac units are NOT interchangeable.
Shipping to 95841 or 95451
what's the part# of the trutrac? I don't recall them being the same for front/rear diffs.
if it is for a solid axle it will work for either front or rear
Originally Posted by joshs84
(Post 50799068)
Care to explain why two different part numbers, one for the front 8" axle, and one for the rear 8" axle? :bigok: |
8" is the same.
Originally Posted by AxleIke
(Post 50799091)
8" is the same.
Detroit Trutrac link |
Because those are different spline counts. Apologies, I didn't read through enough, and thought we were talking v6 to 4cyl.
You COULD put the rear in the front, but you'd need to upgrade to a 30 spline long field set up. |
(Post 50799214)
You COULD put the rear in the front, but you'd need to upgrade to a 30 spline long field set up. You still don't' read enough. :nono: V6, 8", 4cyl., all have the same spline count for the differentials. It's the 7.5" axle that has 27 splines for the differential. |
if its for the 8", yes it has front and rear application... but you could flip the internal gears to make it otherwise
http://www.discoweb.org/truetracgears/index.htm NOTE: after posting, I checked the link I gave above won't work. Maybe you could check again after a while. |
Originally Posted by BOFF
(Post 50799332)
Originally Posted by ted
(Post 50799334)
http://www.discoweb.org/truetracgears/index.htm NOTE: after posting, I checked the link I gave above won't work. Maybe you could check again after a while. Thanks!! I have a front, and I'm going to flip it for the rear axle. |
