I need a 22re Engine asap
I am looking for a cheap complete or possibly good condition lower end in the ohio area to go into my 1988 pick-up which recently broke a rod and distroyed the engine block. If anyone has anything avalible please let me know,
thanks a lot Randy |
complete with intake and accessories runs good but smokes under heavy pedal $275 in knoxville tn
That is a little more than I wanted to spend on somthing that is going to need rebuilt,but I'll keep you in mind. Thanks
how much you lookin to spend? if i can get the motor out of my truck i'd sell it to ya. i'm in leslie michigan. i don't smoke, its just a 22r with the carb setup. the tower is the exact same. you'd have to use your EFI intake stuff. i did a HG on it in july. still needs a little bit of timing work. i dunno how to do it.
I'm near dayton ohio. I'd like to get one for around $100 buck if possible. thanks
most likly thats not happening. the head sells for around that. i'd say 200 would be the lowest you'd find
| All times are GMT -8. The time now is 05:33 AM. |
