1985 toyota 4runner
$4,500 OBO
los angeles CA 1985 toyota 4runner lifted 3.5"-4.5" SR5 interior SR5 seats SR5 cluster tilt meter IFS rear axle 1.5" wheel spacers vented rotor upgrade V6 calipers with new brake pads new alternator V6 radiator 15x10 alum rims 3" bs 33x12.5 firestone M/T still looks new with BUNCH of tread left new MAF sensor new water pump steel back timing chain from Engine builder installed 1 or so years ago marlin extended brake lines bilstien shocks in the back 11" gabriel shocks in the front swapped in a 18 gal fuel tank new belts and hoses 4x4 works manual lock hubs probably some more im missing. the truck will come with all my parts i have laying around which include extra doors ( i wanted to make half doors) 33" tires with 15x10 steel wheels mounted 31" spare brand new leafs extra top extra top which has been cut into a hard bikini top. alot of stuff laying around which i can't remember right now PROBLEMS: engine has a leak front axle can use a rebuild stock steering clutch master is going out so you need to press the pedal pretty low for it to engage. i will post pictures with a better camera tomorrow |
Location?
Originally Posted by eightyfive
(Post 50564200)
$4,500 OBO
los angeles CA 1985 toyota 4runner lifted 3.5"-4.5" SR5 interior SR5 seats SR5 cluster tilt meter IFS rear axle 1.5" wheel spacers vented rotor upgrade V6 calipers with new brake pads new alternator V6 radiator 15x10 alum rims 3" bs 33x12.5 firestone M/T still looks new with BUNCH of tread left new MAF sensor new water pump steel back timing chain from Engine builder installed 1 or so years ago marlin extended brake lines bilstien shocks in the back 11" gabriel shocks in the front swapped in a 18 gal fuel tank new belts and hoses 4x4 works manual lock hubs probably some more im missing. the truck will come with all my parts i have laying around which include extra doors ( i wanted to make half doors) 33" tires with 15x10 steel wheels mounted 31" spare brand new leafs extra top extra top which has been cut into a hard bikini top. alot of stuff laying around which i can't remember right now PROBLEMS: engine has a leak front axle can use a rebuild stock steering clutch master is going out so you need to press the pedal pretty low for it to engage. i will post pictures with a better camera tomorrow Ummm... |
Nevermind I found your craigslist add , and it is $500 cheaper if you buy it off craigslist. Hey, thanks for editting in your location. Any rust problems? I don't care about the carpet and seats but hows the dash and interior plastic trim pieces?
for some reason when i put it on craiglist it listed it $4000 but when you click the link it becomes $4500. i don't understand but it's 4500 OBO and im too lazy to create a whole new craiglist add.
there are NO rust problems whatsoever, it's a cali truck that wasn't on the beach. carpet is clean as i steam cleaned it 7 months ago, seats are semi clean, NO RIPS. dash nice and isn't missing anything. plastic trim is all there...one piece of the plastic trim that goes over the top has a crack in it but it isn't broke. this is a nice 1985 toyota as i put alot of time and money into it. i really don't want to sell but am forced to. anymore questions, just ask... |
http://i4.photobucket.com/albums/y14...g/IMG_1370.jpg
http://i4.photobucket.com/albums/y14...g/IMG_1371.jpg parts that come with the truck http://i4.photobucket.com/albums/y14...g/IMG_1372.jpg http://i4.photobucket.com/albums/y14...g/IMG_1373.jpg this is the full top and the bikini hard top on top of the full top http://i4.photobucket.com/albums/y14...g/IMG_1374.jpg |
wow, i got about 3.50:D i really want a white 1st gen...
