YotaTech Forums
-   The Classifieds GraveYard (https://www.yotatech.com/forums/f180/)
-   -   1985 combo switch (https://www.yotatech.com/forums/f180/1985-combo-switch-141903/)
PartyRunner Apr 4, 2008 08:02 AM
1985 combo switch
I need 1985 combo switch and also instructions on how to remove
thank you
fast68 Apr 14, 2008 05:10 PM
hi there i have an 88 one i removedit today from my 88, it is wipers, lights, and brights, and turn signals, no cruise,
works great, was my daily driver until yesterday and now it is on the car trailer and pretty stripepd of all the goodies including this switch
removal is pretty easy
remove horn cap
remove steering wheel shaft nut
pull wheel off
unplug switch harness plugs halfway down the column, out in the open under the lower dash panel there,
remove the four phillips head screws in the switch holding it to the column
:D
10 minutes tops give or take a couple minutes
good luck!
