YotaTech Forums
-   Tires & Wheels (https://www.yotatech.com/forums/f177/)
-   -   Will 2017 Off-road Wheels fit on 1983 Straight Axel? (https://www.yotatech.com/forums/f177/will-2017-off-road-wheels-fit-1983-straight-axel-304386/)
JBic May 14, 2018 10:40 AM
I’ve looked high and low through the posts. I apologize in advance if this has already been asked.
Will the stock wheels and tires from a 2017 Tacoma fit a 1983 1st Generation straight axel 4x4? If not, what is needed as far as offset.
Thanks.
dropzone May 14, 2018 11:12 AM
you will probably need a spacer up front. 1" would probably do it. but a 10 minute test with a jack and lug wrench would verify
I tried the wheels from my old 05 Taco on my 81 Trekker and had clearance issues up front with the calipers. I was running FJ Rotors with V-6 calipers.
JBic May 14, 2018 01:33 PM
Thank You!
