Anyone running H3 wheels? will they fit?
I love the way that these wheels look especially the safari
wheels. anyone? |
2005-2009 H3 have 6 X 5.5, I bet they're heavy!
wheel measurements are the same, check offset. The wheels weigh more than average toyota stocks or even other wheels. Depends on the tires you put on, you would have to re-gear, or get a lift depends on the tire.
Double check the width of the center bore or hole or whatever its called. alot of GM wheels have the same lug pattern but a smaller hole in the middle.
great thanks ill research it further
Good chance you will need wheel spacers to run them as well.
I wouldnt have thought that they would be that heavy... I mean they cant be heavier then "Rock Crawlers" 10inch wide I just figured it would be a suttle but different touch. I figured I would have to runs spacers given the offset, but i didnt think it would be a problem. I asume by the replys that nobody is running them?
h3 wheels are actually pretty light. if you get them, post pics
I bought a set of used H3 wheels & tires to put on my 94 pickup. Bolt pattern was fine, but I had to machine the center bores out a little to fit. The H3 wheels center bore was too small for the Yota. After machining, I thought I had'er whooped! I did not do what Dad always told me - MEASURE FIRST! The wheels are fine on the back, but due to the backspacing, the tie rod end is against the inside lip of the wheel on the front. They would fit with some wheel spacers. I opted to keep the tires and mount them on different wheels. So.... I have a set of H3 wheels that are machined (professionally) to fit a Toyota that will not work without spacers.
why not use the wheels with wheel spacers?!
I thought about running them with spacers, but ran into a pretty good deal on a set of Black KMC Enduros that will work without spacers.
Saw an old T100 in a parking lot with H3 wheels on it. Looks like it fit the center hole on the ADD hubs just fine.
