2009 Tacoma Wheels on 92 4x4 pickup wheels
Will these 2009 Tacoma wheels fit my 92 reg cab 4x4 truck ? What width are they and what are they worth? I need new tires and I will replace them with 235 or 31" (leaning toward 235) and I have a set of stock steel wheels and aftermarket aluminum (they are very old) Would 15" or 16" be best for me ? Thanks
I believe ALL 6-lug Toyota wheels can be installed just fine on the older trucks. Wheel spacers may/may not be needed depending on the tire choice because I think Tacoma had deeper backspacing, but the lug pattern and bore should fit. Gonna guess this would not be the case for putting older 15" wheels on a newer Tacoma due to brakes interference on the smaller wheels.
You'll have to look up the specs for the specific wheel you want to use as there were a few different ones. The one pictured looks like a Tacoma 16" x 7" - 5.5" bs
smith89panthers
14
05-02-2012 04:44 PM
Vermonster
08-31-2005 11:00 AM
