1983 4x4 cost of regearing to run 33” tires on 15x7 stock rims?
What you got now??
just all stock parts on my truck. Have a new motor from jasper motors and a rebuilt transmission. I’ve been getting some crazy quotes from different shops, pretty expensive. One quote was about $1500 per axle?!?!
front is a little more work.
hence why i suggest you pull them and take them in.
PM Zuk...with parts and shipping you are probably looking at $1500 if you pull them yourself...and it's a good time to go through your front end anyway
600+ install kit
Gear setup labor:
300+
R&R labor:
1500 minus 900 for parts, leaves 600 @ ~100$/hr flat rate shop time.. You think you can pull that all apart and put it back together in under six hours? Keep in mind that hourly rate is way on the low side, it's probably closer to 150. With an aged vehicle they wouldn't be out of line to charge a bit more than normal either to account for seized hardware.
I just had a set of diff assembled at a transmission shop last week. $600 for the shop to put together, $780 in new parts and install kits, and I used two old third member housings I already had laying around.
pat317az
13
04-22-2014 04:45 PM
ianshoots
04-27-2006 08:15 PM
