I bought a 87 4runner with 4.3vortec TH350 swap already done...
You have "gm CPI motor " made from 1992 to 95 . Allmost 200 hp stock .
Good motor but " spider injector " the fuel injector is prone to leaking when they get old . Easy to replace if bad , cost about $175 .
Same motor I have in my 92 4runner.
I would do a basic tune up first then check for a vacum leak , then leaky injector.
If there's puddles of gas in the intake you have a leaking injector. If you put a new injector in , also put the fuel line kit in it to .
Check out this link.
http://www.s10planet.com/forum/showthread.php?t=4342
On the driver side of the intake there should be a vacuum valve with a electrical conector . Your missing hoes from the vacuum port under the butterfly goes to it then keeps going to the charcoal canister.
Looks like this
http://www.oreillyauto.com/site/c/de...2211&ppt=C0018
And yes it need to be hooked up or plugged up. It would be a vacuum leak.
Looks like this
duckhead
170
11-13-2017 06:07 AM
FS[MidWest]: 2001-02 Tacoma/4Runner M/T Harness 3.4
greenbuggy
06-28-2015 10:40 AM
