2JZGTE Swap kit
#124
Parts for swap
I am not sure if this is the correct place to post this, so please forgive me if it is not.
As some of you may know I have been driving/testing my 1994 Pick up with a 2JZGTE (twin turbo Supra) Swap for about a year now. The combination works so well it makes us wonder why Toyota did not do this from the start. I have used the truck for everthing from towing a 22 foot boat (no it does not slow down over hills) to drag racing it at the local track(13.2@100mph traction limited). I currently drive it every day to work, avg. about 20 mpg (not bad cosidering the beating it takes by me and all the guys at the shop).
We are currently putting together parts lists and pricing on a kit. We would like more people to experiance this fantastic combination and would like some feed back on how much call there is for such a swap.
The kit will include the following
1.Bellhousing
2.Clutch
3.Throwout fork,pivot,bearing etc.
4.Pilot bushing
5.Slave cylinder
6.Flywheel
7.Hardware pack
8.Motor mounts
9.Trans mount
10.Down pipe to be used with the stock twins
11.Custom radiator
12.Front mount intercooler
13.Intercooler piping
14.Intake piping and filter
This is not a complete list yet and more info is on the way.
We will be offering special pricing for yotatech members.
Thanks for your time.
Rory
idahospeed.com
1.Bellhousing
2.Clutch
4.Pilot bushing
5.Slave cylinder
6.Flywheel
7.Hardware pack
8.Motor mounts
9.Trans mount
11.Custom radiator
Rory
idahospeed.com
#127
Need to know how to pull off this swap
I am hoping you could contact me and elaborate a little more, i have a 2jz non turbo that i would like to swap into my 91 4x4 just not sure where to start as there is not that many people who have done it.
1.Bellhousing
2.Clutch
4.Pilot bushing
5.Slave cylinder
6.Flywheel
7.Hardware pack
8.Motor mounts
9.Trans mount
11.Custom radiator
Rory
idahospeed.com
1.Bellhousing
2.Clutch
4.Pilot bushing
5.Slave cylinder
6.Flywheel
7.Hardware pack
8.Motor mounts
9.Trans mount
11.Custom radiator
Rory
idahospeed.com
#130
#134
Attachment 180669
Attachment 180670
Attachment 180671
Attachment 180672
1.Bellhousing
2.Clutch
4.Pilot bushing
5.Slave cylinder
6.Flywheel
7.Hardware pack
8.Motor mounts
9.Trans mount
11.Custom radiator
Rory
idahospeed.com
Attachment 180669
Attachment 180670
Attachment 180671
Attachment 180672
1.Bellhousing
2.Clutch
4.Pilot bushing
5.Slave cylinder
6.Flywheel
7.Hardware pack
8.Motor mounts
9.Trans mount
11.Custom radiator
Rory
idahospeed.com
sorry to revive a old old thread but did it ever go threw? Did you make the kit?
#136
2jz nonturbo
I have a 2jz non turbo. I'm not looking to make a fire breathing dragon truck. Just something with better performance than the stock 22re in it. Will y'all have a kit for that?
#138
Hey man! I know I am a few years late but I'm very interested in this kit, where can I get the kit? Also, I won't be able to use stock transmission? Ill have to swap to a R154? Thanks man, please get back at me ASAP, Hopefully you're still around on the forums !
#139
#140
As far as A/C goes we are working on a solution. It will require twin side mount intercoolers instead of a front mount. It will also require going to a big single turbo set up. The stock twins use more room at the back of the firewall right where the A/C under dash unit is.
We will keep you posted.
Rory
idahospeed.com
Rory
idahospeed.com
