Tranny adaptor
Dose any one know if there is an adaptor that will alow me to change a left hand drop transfercase to a right hand transfercase?... im starting my 3.4 swap soon and starting to gather my parts now, i have a 3.4manual engine and trans, and swaping it in to my 91 3.slow auto.
Check marlin crawler.
You will have to get a new tcase though since your auto is a hydraulic controlled build-on/build-off case. |
i have the auto on my 3.0 rnow, the 3.4 engine came with a manual tranny that has a right hansd drop. i will be using a manual tranny weather its the 3.4s with an adapter or a 3.o manual,i have searched marlin,wabfab and inchworm and did not see any,and was wandering if any anybody knew of a company that made them.
will a transfer case off a 3.0 manual tranny bolt on to the manual 3.4 tranny?
They make an adapter to the 4cyl case, but there is zero demand for a rh to lh drop V6 case converter.
Originally Posted by just call me smithy
(Post 51453752)
so should i just look for a 3.0manual tranny then?
that would be easiest. And most likely cheepest in the long run.
ya i figured
Marlin Crawler has an adapter to bolt the 3.4s or 3.0s trany to a 4cyl gear driven T/case. I am running the 3.4 auto trans with one of their adapters. I would look for a 3.0 manual with T/case since it would be cheaper and I would think easier to find. My adapter cost me about $400 and my geared T/case was another $900.
really thats some god news ill have to look in to that. thanks
so you have the auto for your v6? What toyota gave the auto's the better gear driven transfer case? PFFT figures.
ya but its also hydraulic so it likes to suck power from the engine,
