A couple of questions for the pro’s (Auto Trans)
Ok First let me say that I have dual rear wheels… Technically 4 wheels drive :)
My truck is a 1989 2WD 1 Ton dual rear wheel model (Converted to a RV) Stock engine is a 3.0L 3VZ Trans is auto (Column shift) What I have: 1997 4Runner 3.4L 5VZ Auto 4wd engine, all sensors, engine harnesses and ECU Also have a 97 ECU from a 2wd 4Runner, and a 2wd 95 T-100 (5VZ) auto ECU What I’m thinking of doing: I’m going to use the original auto trans. It is a Heavy Duty unit, different from the 2wd trucks. But I need it to shift properly. What controls the shifting? The ECU or different valves/springs in the Trans? (My first time working with auto) I’m going to use the ECU from the 2wd 95 T-100 and the harness from the 97 4runner. The only deference between the two (other than a few switched wire plugs) is the EGR system. My engine (97 4Runner) has nothing and the ECU (95 T-100) has it. Will this be a problem? Thank you!! Andrew. http://i3.photobucket.com/albums/y93/aferg/100_2944.jpg |
1 Attachment(s)
Here is a PDF of the 974Runner VS the 95 T100
2 Attachment(s)
Here are the 2 overall EWD I used for the above chart.
Also, does anyone know what the VSV "TPC" is ? (from the 97 4Runner, 22 Pin connector labeled "F" pin 13, Pink-Black wire color.
I was thinking it was just a re-named FPU (Fuel Pressure Up) VSV, but I thought I should check... Also... :) Did anyone notice that the 2004 Tundra V6 does not use a cross-over exaust behind the engine? (I was looking for new tranny options and saw a picture of them... That's all I know sofar... Hummm...... Thanks! A. http://i3.photobucket.com/albums/y93...TundraAuto.jpg |
