ADD 4 wheel Drive
So i have looked through many builds and i dont think i have seen anyone keep the ADD, everyone seems to be switching to manual hubs.
Has anyone been able to use the ADD? Or know someone who has that i have just skipped over in my research? Thanks everyone |
Love my ADD,but Im all stock and will keep it that way.1990 5spd 4x4,3.0.
I'm sure you can. the difference is the 3.0 is vaccum actuated and the 3.4 is electronic. I guessing it would be easier to re use the 3.0 vaccum set up. keep the VSV on the fender wall. Possible. I like manual hubs and going that route as well.
Mine will have manual hubs. Just makes sense if you can do it as it is less wear and tear on the front components. Besides they look cooler. :hillbill:
:guitar: |
I kept mine, I just wired up the transfer case switch like normal to the 3.4 harness and then tied it in to the body harness inside. went wheeling this weekend and work great. I don't like getting out in the mud or slush to look in the hub (we all know that if you lock them in at the beginning of a trail you have to get out in the biggest mud puddle out there)
i kept mine.
Kept mine, its as simple as a single wire or two I think.
Yeah it is max 3 wires. Easily identified on the ECM diagram.
Well, didn't do the wiring on mine, but I kept ADD too. It's still vacuum actuated at the diff, though.
I kept mine but added manual hubs. I only lock the hubs in winter if i know we're getting snow. Or at the group meet up spot before a wheeling trip. That way i retain my shift on the fly when i'm locked hubs.
any body got pics or instructions that didnt go the manual hub rout.
Originally Posted by waskillywabbit
(Post 51387226)
:guitar:
Originally Posted by yodathespian87
(Post 51387225)
Originally Posted by bansheeboy2x
(Post 51394602)
Originally Posted by vital22re
(Post 51388274)
In that sense, my 86 has shift on the fly too. I'll show you some time :) |
(Post 51394602)
are you just trying to figure out where you need to plug the vacuum lines? |
you don't touch your add stuff. other than splicing the transfer case lines in, and the ADD switch from the front. The vss's and wiring doesn't get touched.
