Wheel Info Needed!!!
Does anyone know if alloy rims off a 2002 4 Runner will fit on a 1990 4x4 extra-cab truck. The bolt pattern of the 2002 rims is 6 lug, 5.5" bolt circle. These have caps on all four rims, but I was wondering if I could take the caps off for the front manual hubs on my 1990 truck.
Any comments are appreciated....Wade |
They will fit, just make sure you use the lug nuts from the later model wheels and you should be OK.
make sure that they are the correct lugnuts for the application rather..... a lot of toyota trucks have standard steel rims and these use a conical seat lugnut... the alloys use both conical or mag-type lugnuts and they are not intercahngeable with each other....
| All times are GMT -8. The time now is 07:19 AM. |
