Vacuum Switching Valve Vsv Constantly Switch / Tick When Running? P0441 Please Help!
hello,
Had the code P0441 I think it is on a 1997 3.4 liter 4 Runner SR5 for the vacuum switching valve, I put in a new one and it seems to constantly tick when running, I never noticed this before with the other one, perhaps because it was bad light was out for quite a few days as I disconnected the battery, reset computer anyway today the light came back on, I opened the hood and could not hear or feel any ticking, switching at the valve like I did the other day when I installed it anyway, I then physically moved the valve itself, wiggled it, right away starting ticking/switching again like it did the other day....perhaps I have a bad connection and it stopped ticking this morning and set off the engine light? do these work consistently while running, or intermittently? maybe jsut a coincidence that it started working when I touched it? please advise! thanks, tim boston ma |
Keeping in mind that P0441 says "Pressure in charcoal canister does not drop during purge control" and "During purge cut-off, pressure in charcoal canister is very low compared to atmospheric pressure".
If you already replaced the VSV then there are really only 2 other options left: 1) Even though you checked, there is still is a vacum leak in one of the lines 2) The EVAP canister might need to be replaced |
I will check the vacuum lines
I am also using a better diagnostic tool that I have here at work I am a marketing director at a transit authority, and they have some sick fun toys in our bus garage so I am going over in a minute I guess the usual starting fluid check for vacuum leaks will suffice? thanks again for the help also dare I ask how much a canister goes for? |
I am also using a better diagnostic tool that I have here at work I am a marketing director at a transit authority, and they have some sick fun toys in our bus garage so I am going over in a minute I guess the usual starting fluid check for vacuum leaks will suffice? thanks again for the help also dare I ask how much a canister goes for? I would use a hand actuated vacum pump to check for leaks on each line (they are cheap if you don't own one). |
first things first, tonight will pull codes right after work, then check vacuum
maybe I can find a used canister... |
Clean the charcoal cannister. Just need some low pressure conpressed air (about 40 psi) and the instructions in the Factory Service Manual.
I will do that
tonight I am clamping all the vacuum lines, a couple of them in the area of the VSV valve do seem a little loose fitting I pulled the code, it said P0441 B...is the B part of this code? I am also going to check out the area near the gas, tank, filler neck etc, I hear that a vacuum leak in that area can also cause these codes? thanks again tim |
just checked all vacuum lines in engine compartment, used soapy water and also starting fluid
i could not find any leaks also blew very light air through the charcoal canister, does not seem to be any leaks in that either |
I will do that
tonight I am clamping all the vacuum lines, a couple of them in the area of the VSV valve do seem a little loose fitting I pulled the code, it said P0441 B...is the B part of this code? I am also going to check out the area near the gas, tank, filler neck etc, I hear that a vacuum leak in that area can also cause these codes? thanks again tim Even though this is for a 2003, the system is still almost the same: http://www.tankota.net/repair/Repair...e/cip0441p.pdf Most of the time when the VSV is bad it will throw both P0441 AND P0446. When a vacuum leak is present, you will likely just see a P0441 OR P0446 (may be some exceptions). You really should get a handheld vacuum pump or at least a vacuum guage to be able to diagnose the problem properly. |
Originally Posted by MTL_4runner
You can use the smaller zipties to secure the ends of the hoses once they check out ok to ensure a good seal for vacuum.
Even though this is for a 2003, the system is still almost the same: http://www.tankota.net/repair/Repair...e/cip0441p.pdf Most of the time when the VSV is bad it will throw both P0441 and P0446. When a vacuum leak is present, you will likely just see a P0441 (may be some exceptions). You really should get a handheld vacuum pump or at least a vacuum guage to be able to diagnose the problem properly. i will get a pump and gauge, before going any further any links to what type of pump i should get? thanks again |
any links to what type of pump i should get? thanks again http://images.canadiantire.ca/media/...0_CC_31f09.jpg or at least a simple guage like this: http://images.canadiantire.ca/media/...50_CC_d0b1.jpg |
1 Attachment(s)
heres a TSB fix for that problem...hope this helps. I was told the same...start with the VSV valve...then the tubing and lastly the charcoal canister (cause thats the most expensive)
-B |
badlands
did you find the source of your problem? if so what was it? |
my light stayed off for 3 weeks and then came on again on a hot humid day...I am replacing the VSV valve first next week...I'll keep you posted.
I was trying the not to top off the fuel to see if it was that...I was also told to replace the rubber seal on the gas cap...so i am replacing seal along with VSV valve....that tsb is the repair for that condition...so i will do step at a time...and if all fails...i'll change the canister last (I hope it doesn't go that far?)
-B |
im gonna replace the vacuum lines, will likely do this tonight, then will check for vacuum leaks once again as MTL has suggested
if that doesnt do it i am, maybe i shouldnt but before replacing the canister i am going to take it out, give it a real hot bath in hot water with palmolive, flush it all out, blow it out with light pressure air hang it out to dry, i also wonder if there is a spot to drill a drain hole then repair it with body panel adhesive or similar then re-install it i have done the same to standard transmissions that were not shifting right, and people would cringe, would re-install throw in synthetic and never had a problem |
replaced vacuum lines,,,,and today light came back on
man o man this is going to drive me nuts! I hope the bath I give the canister will work, but still have to check with a vacuum gauge and pump before I do that... |
if that doesnt do it i am, maybe i shouldnt but before replacing the canister i am going to take it out, give it a real hot bath in hot water with palmolive, flush it all out, blow it out with light pressure air hang it out to dry, i also wonder if there is a spot to drill a drain hole then repair it with body panel adhesive or similar then re-install it i have done the same to standard transmissions that were not shifting right, and people would cringe, would re-install throw in synthetic and never had a problem You might also want to take a look at this: http://aftermarketbusiness.com/after....jsp?id=164723 |
hey
thanks again for all your help first i will use the vacuum gauge and pump check it out then a very careful drill clean and drain may be in order i will let you all know how i make out |
That was a good article MTL 4runner!
boston..let me know how you made out...I'll keep you posted on my repair. And if you find a way to fix the canister instead of replace it...let me know. -B |
| All times are GMT -8. The time now is 10:09 PM. |
