transmission shop
can anyone recomend a tranny shop in the DC/MD/VA area. I have a feeling its something simple and dont want to hear "you need a new tranny" $$$$. it might be a solenoid, TPS or kickdown cable.
Just what are you experiencing with your tranny, "axon".
She doesn't seem to me shifting right (wrong interval) and it seems like no OD at times
You could try adjusting the transmission's "kick down cable" there at the throttle body to remove the slack in it, as this will improve the shifting.
It just may be that the cable has become so loose that it is not going into OD. Other than that, have you checked the transmission fluid level lately... the correct way ?? Info for both of these suggestions can be found with the "search" feature and good luck! :great: |
I adjusted the cable and thats when this all started. but i also did a fluid/filter change to the tranny ...and fluid is good
my tranny has major slippage and wanna know where to get it rebuilt
| All times are GMT -8. The time now is 09:26 PM. |
