YotaTech Forums
-   Maintenance & Repair Archives (https://www.yotatech.com/forums/f16/)
-   -   transfer case problem? (https://www.yotatech.com/forums/f16/transfer-case-problem-57074/)
StevieC Apr 16, 2005 07:39 PM
I discovered that my 4wheel is not working the hard way when I got stuck in the snow recently. Today I put the truck in 4wheel and then tried to turn the front drive shaft by hand and it spun freely. It did so in both 4 hi and 4 low. The truck does however go into the lower drive ratio when its in 4low, but no movement from the drive shaft. Any ideas on why its not working? It's a 91 V6 Auto. Thanks .
StevieC Apr 17, 2005 08:01 PM
Any Ideas?
Eddie Monster Apr 17, 2005 08:30 PM
does it have manual locking hubs on the front wheels? if so u need to lock them ,move the dial from free to engaged.
StevieC Apr 21, 2005 07:27 PM
The truuck has ADD. Like I said, the front drive shaft won't engage, so its a problem with the T-case. It spins freely while in 4wheel with the truck stopped.
93Toyota PU Apr 22, 2005 06:18 AM
Is your dash light on which shows "4WD"?
StevieC Apr 22, 2005 08:57 PM
Yeah the light goes on when I shift it in. I traced the leads for that light and it goes to the front diff. The 4wd light would seem to indicate that the ADD is working. I am wondering if it may be something simple before I tear out my t-case.
eric-the-red Apr 23, 2005 01:29 PM
Does it have push button 4wd, like the newer automatics, if so I think there is a solenoid that switches from 2-4. I'm not an expert on autos, mines a 5 speed, not that I'm an expert on them either but I know a little more :laugh:
I do have a factory manual I can email to you if you want to look at that. If so send me an email address.
StevieC Apr 30, 2005 07:19 AM
It's a floor lever shift for 4wheel. That would be killer if you could send a scan my haynes is not very helpfull.
stephenskis@hotmail.com
george16 Apr 30, 2005 06:19 PM
Check the vacuum lines for any leaks. ADD won't engage fully if there is a leak in the lines.
George
mt_goat Apr 30, 2005 07:15 PM
Here is the 93 FSM, it should be about the same as the 91: http://personal.utulsa.edu/~nathan-b...fsm/index.html
StevieC Apr 30, 2005 07:18 PM
thanks man!
mt_goat Apr 30, 2005 07:25 PM
Your t-case should be the chain drive (VF1A).
StevieC Apr 30, 2005 10:57 PM
Thanks again for th FSM. Based on the drawings I'm guessing it's the linkage to the front drive shift fork or the fork itself. It's a seperate linkage for the hi/low so thats why it can shift into low and not 4wheel. I'll take a look tomorrow.
mt_goat May 1, 2005 05:43 AM
I've heard the chain drive t-cases are weaker but I've never seen a failure first hand. Let us know what you find out. Good luck.
