taking off decals
what is the best way to take off the decals on my 93 pickup? they started to peel when i was using my pressure washer. so i want to just take them all the way off. what works best?
What I did
I kept my finger nails long enough until I was done (not normal for me) then I bought a bottle of googone. I would get a hairdryer aswell being its not the best time of year to be doing this project. heat it up, squirt on googone, then use your nails to scrape off the material. I did mine in fall and have only asmall patch on the rear paneling of my runner that will wait until it warms up to get off. Good luck.
3M makes a adhesive remover in a spray can application. Works well. Second idea is to use a hair dryer. I have used both with success.
Belt sander works well.:bigok:
i used a hair dryer ( it was summer time when i did it) and used some goo gone on the adhesive left over too
a word of warning though.................the goo gone will ruin any plastic , so if you have extenda fender flairs on like i did make sure you dont get any of that stuff on them (luckily i was able to repaint them) |
3M has an adhesive remover. I took off all my stripe decals, took a while after trying several different approaches. I actually put up a post on it. Try a search, decal remover.
| All times are GMT -8. The time now is 12:32 AM. |
