YotaTech Forums
-   Maintenance & Repair Archives (https://www.yotatech.com/forums/f16/)
-   -   setting timing 22r (https://www.yotatech.com/forums/f16/setting-timing-22r-4449/)
jchef Dec 17, 2002 04:07 PM
setting timing 22r
:bang: hi guys, need some help. I blow out my head gaskit a while ago after replacing the gaskit and reassembly it i cann't get it to stay running the timming will set to the marks but have to idle at 2000 rpms to stay running any ideas thanks:cheers:
Jay Dec 18, 2002 11:34 PM
But does it run good at 2000? Or pretty crappy?
Is the timing chain on correctly? Is the distributer properly alighned? Does the distibuter securing bolt line up close to where it use to? ( about in the middle of the slot your given?)
Vacuum leaks?
Jay
