Rod Bearings
Old Nov 6, 2003 | 03:27 PM
merrill94's Avatar
Rod Bearings
I'm changing the Rod Bearings on my '86 4x4 pickup. I need help determining the size bearings I need (Standard, 25 over, etc.). My Haynes manual says to determine the size get the letter off of the rod bearing cap (A, B or C). The letter on my caps are B. What the manual doesn't tell you is how this carries over to the size. I'm thinking since mine is a B it means 25 over. Any help here sure would be appreciated. The service dept at the local Toyota dealer was clueless to what I was talking about. They only order them as A, B or C.
Old Nov 6, 2003 | 03:51 PM
DarylD's Avatar
If your crank hasn't been turned you can just use the standard size bearing's . Go to the Toyota parts dept. and ask for the std. bearings and they should ask you A,B, or C. Don't forget to plastic gauge.
Old Nov 6, 2003 | 03:57 PM
Robinhood150's Avatar
Hey merrill94, I moved your previous post over to the maintenance section and I'm going to move this one too. I'll have the maintenance moderator merge these two threads.
Old Nov 6, 2003 | 04:35 PM
Bob_98SR5's Avatar
merill, et al:
i deleted the other thread b/c there were no replies.
bob
Old Nov 6, 2003 | 06:40 PM
merrill94's Avatar
Thanks, my next question is what about if I go to Auto Zone to get the bearing. They don't know what A, B or C means. Or is that more the reason to go to Toyota.
hiluxinargentina
Sep 30, 2015 05:51 PM
tylermx71
Sep 29, 2015 08:49 PM
EVars
Sep 29, 2015 02:06 PM
voiddweller
Sep 28, 2015 11:21 PM
Pitbullblues
Sep 19, 2015 08:19 PM
