YotaTech Forums
-   Maintenance & Repair Archives (https://www.yotatech.com/forums/f16/)
-   -   Replace CV's? (https://www.yotatech.com/forums/f16/replace-cvs-54204/)
Tacoma750 Mar 14, 2005 04:49 PM
Replace CV's?
Is this a saturday project for me? Im good with tools and my hands, and im good at taking things apart and putting them back together. Would replaceing my CV's be something i could do in my garage? WHat would I need to do it..(besides new cv's lol)
calrockx Mar 14, 2005 04:55 PM
if you're just replacing a bad cv axle with another built one, it's easy.
you can do both sides in under 2 hours easily. much faster once you have some experience.
you'll need some ratcheting wrenches. i forget the sizes, but at least one 35 mm fitting (for a 3rd gen 4runner at least). a breaker bar helps too.
search and you should be able to find some writeups.
Jeffires Mar 14, 2005 04:56 PM
It's been a while since I did mine...not too bad of a job. I had torn boots, so I pulled my axle shafts and took them to a front end shop (because I didn't have to tool to recrimp the band that holds the boot on). Are you swapping new ones are rebuilding the old ones?
http://img.photobucket.com/albums/v6...0/DSC01809.jpg
I'm trying to find all of my pics when I pulled it...
Tacoma750 Mar 14, 2005 04:58 PM
im thinking just putting new ones in...
Robinhood150 Mar 14, 2005 05:32 PM
Judging by his name, I'm guessing he's got a tacoma which is completely different from your CVs.
BTW, you don't need the tool to crimp the clamps, I just used my fingers and something to mash down the tabs.
Jeffires Mar 14, 2005 05:50 PM
I knew of someone who didn't use it and had problems, so I took it to a buddy at the alignment shop to let him inspect it, pack it with their grease, and recrimp it with new bands he had.
hamstrungtaco Mar 14, 2005 07:47 PM
are they damaged? if not why bother replacing them if theyre still intact :think:
Shane Mar 14, 2005 09:08 PM
This sounds more like a MAINTENANCE topic than a FABRICATION topic... Moving...
Tacoma750 Mar 15, 2005 11:44 AM
i have a 1stgen 4runner. thx for the tips guys
Robinhood150 Mar 15, 2005 12:20 PM
In that case search around, there's some pretty good posts about how to do it.
