Power Steering Pump replacement.
Any advice on installing a new powersteering pump. I've got the new one in already, just haven't found time or resources to do it.
http://www.nzdiary.com/images/ps_pump.jpg This is a pic of the old one. Notice the leaks! The steering wheel hums when I turn it, though no real resistence yet. |
How much did you pay for the new one? When I ahve priced them they are $$$$
I ordered it from Jay Mark Toyota. I believe it was about $275 or so.
More than I wanted to pay, but cheaper than a new car payment. |
Sorry, I don't know anything about replacing them, other than what my Chilton's says.
I had to replace mine pump and Steering gear this weekend. The only think that I can tell you is that it was some what easy,and be sure to not get any dirt in to the fluid on lines. It will blow out your seals. you think it's leaking now, what till the seal go! Good Luck! I'm glad to more people turning wrench!:welder:
how to change your p/s pump:
remove belt remove old pump install new pump remove pulley from old pump install pulley on new pump reinstall belt, tighten fill resevoir with fluid start engine, re-fill while running reinstall cap good to go! lol |
| All times are GMT -8. The time now is 06:13 AM. |
