YotaTech Forums
-   Maintenance & Repair Archives (https://www.yotatech.com/forums/f16/)
-   -   leak on transfer case need help (https://www.yotatech.com/forums/f16/leak-transfer-case-need-help-58805/)
Lone4runner May 10, 2005 10:30 AM
just found a leak on the bottom of my transfer case what causes this usually and is it common once i get to 90k on my 99 4runner ?
4Crawler May 10, 2005 10:45 AM
Clean it up and find where the leak is coming from. Then the solution will probably be more apparent. If it comes from a seam, try tightening the bolts holding that part together, up to the factory torque spec if they are loose.
Lone4runner May 10, 2005 11:51 AM
thanks. i just panic too much for the past month ive spent almost 2 g's fixing the thing one after another due to maintenance & my stupidity.
rimpainter.com May 10, 2005 11:57 AM
I just fixed a very similar leak on my 96. My 96 has 88K miles on it. I discovered it was leaking from the transfer case output shaft seal, a $10 dealer part. It took me about 1 hour with air tools and taking my time. You will need a pry bar to get the output shaft flange nut loose. You will also need something to hold the shaft flange in place while you are reefing on the pry bar. I bent up a steel bracket and bolted it into place, preventing the shaft flange from turning.
The dealer wanted about $100 to do this. I decided to save $90 and do it myself. On a scale of 1 - 10, 10 being a motor swap, I would rate this a 4.
No more leakage. :)
