YotaTech Forums
-   Maintenance & Repair Archives (https://www.yotatech.com/forums/f16/)
-   -   I got the beeps, the creeps, and the bleeps...(clutch) (https://www.yotatech.com/forums/f16/i-got-beeps-creeps-bleeps-clutch-60194/)
GodwinAustin May 31, 2005 09:53 AM
As they say...
Whenever I engage the clutch there is a creaking noise coming from somewhere under the truck.
I cant hear it inside, or when the windows are closed.
Its not loud and really only noticeable while engaging the clutch at a stop or in a parking lot.
Any ideas, can I lube something up under the truck?
thanks :drink:
GodwinAustin May 31, 2005 09:54 AM
This is not the return bushing as I have dealt with that before...
bamachem May 31, 2005 10:04 AM
probally the linkage on the housing. my old 79 did that... push in the clutch w/ the windows down and you hear creeeeeakkkk! on that one, it had an old linkage w/ a pivot that had metal-to-metal contact. i caked some marine grease on the pivot for the cable, and it quit.
Silver_Truck May 31, 2005 10:32 AM
I'd say linkage or the clutch pivot point for the actual pedal
GodwinAustin May 31, 2005 11:20 AM
where is this so called "linkage" located? is it next to the tranny? I learn as I go as far as maitenence goes and havent dealt with the clutch or any of its parts...could someone point me in the right direction so I could try to through some grease on this thing?
rimpainter.com May 31, 2005 11:22 AM
How long ago?
GodwinAustin May 31, 2005 12:09 PM
Christian, a couple months ago....that was an interior noise when I dealt with it.
This is entirely external.
rimpainter.com May 31, 2005 12:40 PM
OK cool. Have you stuck your head under there by the clutch release fork while someone pushed the clutch pedal in and out? That will help you narrow it down. I bet the squeak is coming from that pivot point.
Silver_Truck May 31, 2005 01:42 PM
:good: thats the linkage I was talking about down at the slave cylinder/ fork while your down there check to see if your slave cylinder is leaking or shot (easy to tell theres fluid all over the motor, bellhousing, transmission, frame etc.) Also while your on the subject of squeaky clutches hit the pedal pivot point w/some WD40 just to prevent it from squeaking on you
