YotaTech Forums
-   Maintenance & Repair Archives (https://www.yotatech.com/forums/f16/)
-   -   Help!!!! timing/vacuum???? (https://www.yotatech.com/forums/f16/help-timing-vacuum-58661/)
timk2915 May 8, 2005 12:58 PM
We just put in a new 22re and seem to having the timeing right on target, idles perfect but as soon as you touch the throttle, no matter how much it just jump and cuts out completely at about 1600rpm?!?!?!?! is a vacuum hose maybe in the wrong place?? What could cause this problem...... Please help need to be back homew tomarrow for work!!!!!!!!!! Thanks for your time,
TIM
SoCal4Running May 8, 2005 04:47 PM
Is the TPS properly adusted?
timk2915 May 8, 2005 05:00 PM
How do you adjust the TPS unit or know if it's properly adjusted. The truck runs pretty well with it disconected but idles higher and seems to pull rather weak no matter where we adjust the timing....... Can I hurt something by running without the sensor hooked up till I can fix the problem??? Please let me know and thanks again for the time....... TIM
SoCal4Running May 9, 2005 04:36 PM
Basically the TPS tells the computer when the throttle is at idle and when it is at wide open.
If yours runs without it hooked up then yes it will run without it hooked up but the computer will have no clue what is happening with the throttle.
Check out Mr. Browns site here for the answers to your questions about the TPS. He knows all :bowdown:
