| 4Peanut |
May 16, 2005 06:35 AM |
Fuel Filter Replacement: Compression Fitting Problems
Well, the rear compression fitting loosened without issue, but after more than 200,000 miles the front fitting will not budge. I am using a 14mm open-end wrench on the fitting, and a 19mm open-end wrench on the filter housing itself for leverage. Even two applications of PB Blaster have not helped. I have a few questions out there for the experienced as I watch the sides of my fitting begin to round off: - First, will a crow's foot wrench be that much better at loosening this fitting?
- Second, if the fitting loosens, but becomes rounded off in the process, can it be replaced? I have some experience with compression fittings in around-the-house plumbing projects - is this similar?
- Third, since I have to buy a set of crow's foot wrenches, should I buy the open-end type, or the type that attach to a socket drive?
- Lastly, should I just drive it to the dealership and let them deal with it?
Thanks in advance for your input.
Brian
