Front Wheel Bearings
I just found this site and I have to say I am impressed! It's very cool!
Now to my question: I have the front wheels off my '87 4-Runner and the races look ok. However the bearings have a bit of lateral slop in them when I push (gently)... is this suppossed to be there? Oh one more... how on earth does anyone measure the ft/lbs for tightening the adjuster nut? It's huge (about a 2.25 inch nut) and I have noooooooo way to get my torque wrench on it. Thanks a bunch! Shane. |
What do you mean you can't get the torque wrench on it?:) Do you mean that the socket is a 1/2 inch drive and you have a 3/8 inch drive? Or do you mean you don't have the 54mm socket to fit over the nut?
Steve |
Hi Steve,
The adjuster nut itself is about 2.5 inches in diameter and about 1/8th of an inch thick. It is a huge flat nut! :) What I was wondering is if there is a way to measure this without buying a socket to fit the large diameter of the nut? Thanks. Shane. |
I'd think the easiest way is to go buy the 54mm socket (Thats what it is on mine anyway). It's about $20 at the auto store. You can also do a search at 4x4wire.com about this, as the socket size has been talked about a lot over there.
Good luck Steve |
Re: Front Wheel Bearings
Originally posted by kandscanada I just found this site and I have to say I am impressed! It's very cool! Now to my question: I have the front wheels off my '87 4-Runner and the races look ok. However the bearings have a bit of lateral slop in them when I push (gently)... is this suppossed to be there? Oh one more... how on earth does anyone measure the ft/lbs for tightening the adjuster nut? It's huge (about a 2.25 inch nut) and I have noooooooo way to get my torque wrench on it. Thanks a bunch! Shane. |
