YotaTech Forums
-   Maintenance & Repair Archives (https://www.yotatech.com/forums/f16/)
-   -   coolant leak (https://www.yotatech.com/forums/f16/coolant-leak-25801/)
yoda92 Feb 1, 2004 07:40 PM
coolant leak
Im trying to sell my 92 4runner but it has a coolant leak. I cant locate where it is leaking other than its on the back of the motor. I can see steam coming from the back pasenger side of the engine. I checked the hoses back there but i cant see anything leaking. I do see a circular shaped thing like a plate with 2 bolts holding it in place and it feels a little wet on the bottom side of it . Im not sure what it is or if it has anything to do with the cooling system . Does anybody have any ideas?Thanks
Aaron
amusement Feb 1, 2004 08:30 PM
A freeze plug? Or someone removed a engine heater and replaced it with a bulk head.
Good luck.
kford Feb 4, 2004 07:27 PM
Water pump. I'm not a professional but i've had tons of coolant problems from high pressure build up cause of brakes to freeze plugs to water pumps, and that sounds like a water pump. Kind of expensive (like 250 maybe) to get replaced by stealership.
