Answer needed ASAP
Where are the connections located that I need to connect a jumper wire so I can check the timing? I need to go to work so can someone post the answer in the next 5 minutes. :great:
Hi -
On my 1989 pickup with the 22RE, it is E1 and Te1 , I THINK. Although I did this yesterday, I am not 100 percent certain. Didja try searching on the forum? I am sure this is posted somewhere. I if you look at the diagnosis plug, it has a number of holes. From memory, I am doing the left side of the plug only and using X for no and O for where the jumper goes. ENGINE X X O X X O X X X X X X FUSEBOX FENDER For your own good, I encourage you to confirm this! Good luck. |
| All times are GMT -8. The time now is 02:23 PM. |
