YotaTech Forums
-   Maintenance & Repair Archives (https://www.yotatech.com/forums/f16/)
-   -   2 problems, 1999 runner (https://www.yotatech.com/forums/f16/2-problems-1999-runner-60234/)
mike_04 May 31, 2005 07:00 PM
1) the odd time when i get into my truck my clock does not work. but the second i press any of the buttons to set the time it come right back on.
2) when i first get into my truck the first couple of time i hit the brakes this makes a "cluncking" noise. i took to a shop and they said my brakes look good. lots of meat on the drums and my front pads could be replaced in about 4 months. any ideas...i hate it when my truck is not running perfect.
rimpainter.com May 31, 2005 07:02 PM
Can you describe the clunking noise in greater detail? Tell us more about when it happens...what speed, how hard you hit them, etc.
Any recent brake work? Are you the original owner?
mike_04 May 31, 2005 07:11 PM
i have had the truck for 2 years. second owner. personaly i have had no work done. ok when i put my truck into recverse touch the brake normaly it makes a small clucking noice. put her in drive it the first stop sign or when ever i have to hit the brake, no matter how fast or slow i'am going. or how hard or soft i hit the pedle it will make the same noice.. after pressing the brake peddle about 3 times not matter how hard i try it will not make the noice again unless i park it for a while......weird!!!!
rimpainter.com May 31, 2005 07:13 PM
Try to duplicate it, only do it in neutral as you roll to a stop. Let us know if the clunk is still there.
BajaRunner May 31, 2005 07:35 PM
Same clunking I was experiencing.
I just took out the ABS plugs and cleaned them really well with CRC electrical connector cleaner and so far so good.
BruceTS May 31, 2005 08:44 PM
check your suspension links and shocks. There's a possibility one of them is loose or broken.
tv4184 Jun 1, 2005 09:38 AM
I have experienced this problem as well in both my 99' and 97'. I just assumed it was normal and happens until the brakes set after sitting in park for so long.
MTL_4runner Jun 1, 2005 09:58 AM
Could also be the driveshaft that needs to be greased......often makes a big "clunk" when braking if not lubed.
Lance Jun 2, 2005 06:54 AM
I have the same clock issue. I just tap the dash around it and it comes on.
I am just waiting for it to die.
rimpainter.com Jun 2, 2005 09:37 AM
Yeah, that's exactly where I was headed with my post.
mike_04 Jun 4, 2005 10:47 AM
well sounds good as long as it's nothing serious....
