YotaTech Forums
-   Maintenance & Repair Archives (https://www.yotatech.com/forums/f16/)
-   -   1st Gen rear window repair (https://www.yotatech.com/forums/f16/1st-gen-rear-window-repair-59191/)
Tiger Paw May 16, 2005 09:11 AM
My teeth on the motor gear are stripped and the lift rail is rusted on both sides so the window has stopped going up and down unless I give it a little "assistance." I'm pretty sure the teeth are stripped because I can hear the motor running while turning the key and it slides down by itself while I'm driving. I did a search and it seems someone else had problems with stripped teeth on their motor. Before it stopped going up and down on its own, it used to make a clunking noise while going up and down like it had a broken gear tooth somewhere. Even if the motor and the gear are o.k., I still need to replace the liftrail. My questions are:
1) Can I replace just the gear on the motor or do I have to replace the whole motor?
2) There is a connector on the driver's side of the lift rail and two wires hanging loose in the tailgate. Are they for the defrost or do they go to something else?
3) I know I have to take the carpet and the plastic off to get to the whole window assemby, but how do I get the assembly out of the tailgate? Do I need to take the glass out of the liftrail first or what? A step-by-step would be nice. There isn't alot of room to work with in the tailgate and I can't quite figure out how to get the motor and regulator assy. out. :think:
My runner is an 89, BTW.
4Crawler May 16, 2005 09:33 AM
Some ideas on my web page:
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Have not done any mechanical work on my '85 window, but on my old FJ55 Landcruiser I had a gear strip on the motor. Had to buy the whole motor and some other parts as an assembly from Toyota. I ended up just pulling the gear off the new motor and put it on the old motor while it was still in place.
Tiger Paw May 16, 2005 10:39 AM
Thanks, Roger. You're right, I'll probably have to buy the whole motor assy. unless I can find one with a gear in good condition. Now I just have to figure out how to get everything out of the tailgate so I can replace the gear on the motor.
Tiger Paw May 16, 2005 12:30 PM
Anyone have any info on how to get the regulator assy. out or what the two loose wires go to?
