YotaTech Forums
-   Engine Swaps (https://www.yotatech.com/forums/f158/)
-   -   No oil pressure (https://www.yotatech.com/forums/f158/no-oil-pressure-153377/)
Toyota_Pilot 09-04-2008 01:33 PM
No oil pressure
Just finished my motor swap with a new 22re, its runs but i have no oil pressure. I replaced the oil pressure sensor. When i turn it on the pressure gauge comes off of the peg but its just below the operating arch. what can i check or change without ripping the motor apart again?
Toyota_Pilot 09-04-2008 01:53 PM
its exactly the same as the old engine. It came with a new pump installed by www.sunwestautomotive.com
TOYOTA 1 09-04-2008 01:58 PM
hmm.. do you have a manual one handy?
Toyota_Pilot 09-04-2008 02:55 PM
a manual oil pressure gauge, no. the repair manual, yes but i didnt see anything on trouble shooting low oil pressure
TOYOTA 1 09-04-2008 03:04 PM
i was talking about a gauge.. see if you can get one then check for oil pressure! that will tell you if its the gauge, or not. eliminate the idea of a faulty gauge.
just my .02
Adam F 09-06-2008 06:01 PM
Use an oil pressure tester and see what your actual oil pressure PSI is
2017 InternetBrands, Inc.
