Engine Swaps Swapping an engine in your Toy, here is where to learn how
New area (Engine swaps)
Old Nov 21, 2007 | 01:45 AM
Corey's Avatar
Co-Founder/Administrator
It has probably been brought up in the past, but YotaTech member "thefallman" Brian had a suggestion for an engine swap section since there is at least one going on at any given time.
If it gets really busy we can break up the section by engine categories, but lets try this and see how it goes.
Old Nov 21, 2007 | 04:37 AM
ozziesironmanoffroad's Avatar
thats a good idea.
Old Nov 21, 2007 | 04:43 AM
Corey's Avatar
I agree.
If someone wants to scour the site and add all the URLs to the current swaps to this same thread here, I can move them into this section when I get a chance.
Old Nov 21, 2007 | 06:23 AM
Elvota's Avatar
Mt. Goats super monster :
https://www.yotatech.com/forums/f116...started-82145/
Breknraj:
https://www.yotatech.com/forums/f116...warning-93642/
and here is mine:
https://www.yotatech.com/forums/f116...4-swap-128285/
But I haven't been able to start it just yet. Will start updating my progress when I begin in a week or two.
Just to get things rolling...
Old Nov 21, 2007 | 07:48 AM
Corey's Avatar
Thanks, still looking into sub forums, as we may need them with all the thread.
OK:
3.4 Swaps, V8 Swaps, Diesel Swaps, I4
Swaps and Other Swaps
Is I4 the Supra?
The above would cover all correct?
PS, the other sections will not happen until later tonight or Thanksgiving, I do not have the time at work to do it.
Old Nov 21, 2007 | 08:01 AM
Elvota's Avatar
As in, the above suggested subtopics would cover all swaps?
There seems to be an infinite amount of options for swaps. Ford, Buick, Chevy... endless list.
Maybe if sub topics are needed, you could have something like "Toyota Swaps", "Domestic Swaps", "Diesel Swaps"... etc. Less sub topics but still helping people search for info they are interested in.
Just throwing out ideas.
Old Nov 21, 2007 | 09:03 AM
Cebby's Avatar
Is I4 the Supra?
I4 is usually the 3RZ Taco motor into older trucks.
Supra is I6.
Old Nov 21, 2007 | 09:09 AM
thefallman's Avatar
When i suggested the topics to corey i tried to group them according to the tech base needed for each swap. The problem you run into is that the there are several domestic diesel and toyota diesel swaps available. Then you have the V6 4.3L Chev people. The small block GM and Ford people, and the V8 toyota people,
I think i agree with evolta in a way about this though let me revise my suggested list of sub forums.
3.4 Swaps,
Domestic Swaps,
Diesel Swaps,
Other Toyota Swaps,
Later we may need such things as a UZ toyota V8 swap section and what not, But for now i think that, that is probably the best division since, the main swaps happening from what i can see are 3.4, then domestic V8 or V6, then Diesel.
edit. although if anyone wants UZ swap info there is more then enough at cebby's site
Old Nov 21, 2007 | 09:23 AM
yotasavg's Avatar
that's a really good idea. i think this will clean up the 86-95 section considerably, plus it may draw more attention to YT through google searches and whatnot.
Old Nov 21, 2007 | 10:58 AM
idayota's Avatar
i like it! it would be a great help to have all these threads grouped together, especially when someone is considering a swap or mid-stream in a swap and needs some tech assist.
categorizing them by make is a good idea, too.
Old Nov 21, 2007 | 01:11 PM
Corey's Avatar
Sections are up, and this sub forum here could be left intact for general BS'ing about swaps or it could go away and get absorbed into the others.
Also here is a screenshot of the current setup.
The category bar (Engine Swap Talk) could be left in the Off Road/fab section here, or it could have its own category below the Off Road title bar.
Thoughts?
Old Nov 21, 2007 | 01:18 PM
olharleyman's Avatar
may need to upsize that pic its so tiny when I look at it maybe its my puter but it seems the right idea. I like the way it breaks up the motors and swaps easy to find the 3.4 vs. the chevy v8 and ford vs. diesal good start love to see it done before I do my S/C 3.4 swap.
Old Nov 21, 2007 | 02:16 PM
idayota's Avatar
i think you should leave it where it is...good placement...easy to find. i would also leave up the general "engine swaps" area for general bs and motor swap related info. looks good corey.
Old Nov 21, 2007 | 03:00 PM
Corey's Avatar
Thanks, but thank Brian too.
Just moved the other ones from Elvota's post above.
Forgot all about them until now.
Running around here cleaning my home and doing other chores before the holiday.
Old Nov 21, 2007 | 09:05 PM
thefallman's Avatar
Engine Swap Threads
General Threads
https://www.yotatech.com/forums/f116...s-3-4l-128836/
https://www.yotatech.com/forums/f116/v6-swap-128860/
https://www.yotatech.com/forums/f120...d-i-go-128004/
https://www.yotatech.com/forums/f116...r-swap-127368/
https://www.yotatech.com/forums/f116...ilemma-124227/
https://www.yotatech.com/forums/f116...-3-4-a-122945/
3.4 Swap Threads
https://www.yotatech.com/forums/f116...p-info-128625/
https://www.yotatech.com/forums/f116...ulleys-128662/
https://www.yotatech.com/forums/f116...rrible-127119/
https://www.yotatech.com/forums/f2/n...h-3-4l-119029/
https://www.yotatech.com/forums/f131...-wires-127494/
https://www.yotatech.com/forums/f116...4-swap-126948/
https://www.yotatech.com/forums/f116...-again-126371/
https://www.yotatech.com/forums/f116...issing-126346/
https://www.yotatech.com/forums/f88/...-w-auto-43167/
https://www.yotatech.com/forums/f116...-a340h-128200/
https://www.yotatech.com/forums/f116...project-76528/
https://www.yotatech.com/forums/f123...runner-122396/
https://www.yotatech.com/forums/f2/3...ng-hot-124438/
https://www.yotatech.com/forums/f116...-3-0-l-126092/
https://www.yotatech.com/forums/f116...4-swap-124890/
https://www.yotatech.com/forums/f37/...ersion-125683/
https://www.yotatech.com/forums/f88/...4-swap-114151/
https://www.yotatech.com/forums/f116...4-swap-124055/
https://www.yotatech.com/forums/f116...4-swap-124169/
https://www.yotatech.com/forums/f116...needed-116383/
https://www.yotatech.com/forums/f116...e-swap-121938/
https://www.yotatech.com/forums/f116...p-guys-115082/
https://www.yotatech.com/forums/f116...-issues-95003/
https://www.yotatech.com/forums/f116...um-hose-93473/
Other Toyota
https://www.yotatech.com/forums/f116...ngrade-127973/
https://www.yotatech.com/forums/f2/s...3-0l-v6-53160/
https://www.yotatech.com/forums/f115/22re-swap-126114/
https://www.yotatech.com/forums/f116/v6-v4-125578/
https://www.yotatech.com/forums/f116...estion-125467/
https://www.yotatech.com/forums/f161...4runner-54771/
https://www.yotatech.com/forums/f116...e-done-125481/
https://www.yotatech.com/forums/f116...e-swap-125443/
https://www.yotatech.com/forums/f123...2jz-ge-125020/
https://www.yotatech.com/forums/f116...bility-124906/
https://www.yotatech.com/forums/f116/3-0-22re-123173/
https://www.yotatech.com/forums/f115/7mgte-swap-119777/
https://www.yotatech.com/forums/f116...-truck-116836/
https://www.yotatech.com/forums/f116...e-22re-122679/
https://www.yotatech.com/forums/f116...e-swap-122554/
Diesel Swaps
https://www.yotatech.com/forums/f116...l-92-a-128133/
https://www.yotatech.com/forums/f116...l-swap-119493/
https://www.yotatech.com/forums/f2/1...-texas-126657/
https://www.yotatech.com/forums/f116...estion-126439/
https://www.yotatech.com/forums/f107/2lt-diesel-82925/
Domestic
https://www.yotatech.com/forums/f2/c...2nd-gen-20592/
https://www.yotatech.com/forums/f116...o-down-124834/
https://www.yotatech.com/forums/f116...runner-127771/
https://www.yotatech.com/forums/f88/...8-swap-125942/
https://www.yotatech.com/forums/f88/...e-r150-126624/
https://www.yotatech.com/forums/f116...runner-117986/
https://www.yotatech.com/forums/f116...8-swap-129719/
https://www.yotatech.com/forums/f116/302-126236/
https://www.yotatech.com/forums/f116...l-swap-124494/
https://www.yotatech.com/forums/f116...-trans-121086/
https://www.yotatech.com/forums/f123...-runner-96431/
https://www.yotatech.com/forums/f123...eating-124018/
https://www.yotatech.com/forums/f116...-motor-122674/
https://www.yotatech.com/forums/f88/...ctures-111584/
Corey i tried to weed out the ones that didnt have any useful info kinda hard sometimes though cause alot of times somebody will have a new question that brings up some good issues so anyway heres a list of the threads i found that i think should be moved into our new section. All of them deal directly with swaps.
Old Nov 22, 2007 | 05:56 AM
Corey's Avatar
Thanks Brian, that is a HUGE list
I will scour over it later.
Old Nov 22, 2007 | 06:55 PM
breknraj's Avatar
Thanks for the work, both of you!
I'm sure that this will be a big help to anyone looking into a swap.
Old Nov 23, 2007 | 08:00 PM
thefallman's Avatar
This needs to be moved to Other toyota swaps area
https://www.yotatech.com/forums/f158...0-ypta-130573/
and we need a sticky about posting specific swap questions in specific swap areas same with specific swap info. general questions about swaps and the merits of one swap verses another should be the only thing in this area. It will keep it alot cleaner and is the reason for those sub-forums creation
Old Mar 1, 2009 | 04:06 AM
96whiteexttacoma's Avatar
96 tacoma 1uzfe engine swap
i am wanting to do a 1uzfe swap with my 96 v6 auto tacoma, i am wanting to know what i am getting myself into, how hard is it, what all adapters i need, how much will it cost after the purchase of the engine, and how long will it take? does anyone know or of heard of a successful 1uzfe swap into a pre-98 taco? any input is greatly appreicated, i am currently in iraq and wanting to do the swap before i got home on leave, i will have about 2 weeks to do it from the time i get back
Old Mar 1, 2009 | 04:16 AM
Corey's Avatar
You will have to make a new thread with your question, as this thread is only to announce the new engine swap sections here at YotaTech.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
coryc85
Sep 9, 2015 06:24 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
toyoda8488
Jul 5, 2015 10:18 PM
HRDC0R19
Jul 5, 2015 06:43 PM
