Engine Swaps Swapping an engine in your Toy, here is where to learn how
88 Toyota 1UZ Swap plus MORE!!!!
Old 05-29-2009, 07:19 PM
  #41
gennro's Avatar
Having problems with the ECU wanting to stay in backup mode. So been troubleshooting everything on that engine. So at the least I may have to buy another ECU.
I do have radiator fans now bought 2 perma cool 10" 2300CFM that will hopefully do the trick. They are the highest flowing fan for the size.
The exhaust is almost done just gotta finish welding one more flange to hook up the 2' 3" glasspack that i have for it.
Old 05-29-2009, 07:44 PM
  #42
toylocost's Avatar
Location: Yotatech, because Pirate is too expensive. NorCal.
We need more, better, pictures and a video...
Old 05-29-2009, 09:52 PM
  #43
RMA
RMA's Avatar
Gennro what radiator are you using those fans on.
Hey why do you need it to run in back up arnet you using everything from lexus i mean all the original wiring ,sensors,ecu and such.
any way good luck really hope you get it going .
Old 05-30-2009, 05:29 AM
  #44
gennro's Avatar
I'm using a new 22R-TE radiator its a 3 core instead of the stock 2core. I could run no fans when i had my 22r in there. The hoses are just from flex hoses from advance auto
Old 05-30-2009, 11:27 AM
  #45
gennro's Avatar
The ECU that I had was bad, So found a 91 ECU at a junk yard and now the truck runs great. I got it warmed up and it started overheating. I'm just using water right now so i am going to pull the thermostat and put some real antifreeze in there and maybe some water wetter. Then do a good air bleed to it also because i haven't bled any of the air out yet. It did take it like 45 minutes for to finally start overheating though sitting in a hot garage.
Old 05-30-2009, 03:36 PM
  #46
gennro's Avatar
UPDATE: Redline water wetter and prestone antifreeze does the trick for the overheating. Also stay tuned for some pics later.
Old 05-30-2009, 03:38 PM
  #47
waskillywabbit's Avatar
If you are overheating you got air in your system.
Old 05-30-2009, 04:26 PM
  #48
wslytoy's Avatar
and FYI, Toyota red coolant is much better than the green crap.
Old 05-30-2009, 07:19 PM
  #49
gennro's Avatar
thats what i have heard
Old 05-30-2009, 07:42 PM
  #50
gennro's Avatar
Old 05-30-2009, 08:28 PM
  #51
RMA
RMA's Avatar
Glad to see you got it running.
Hey I see 3 relays does this mean you are using a 1 speed fuel pump and not a 2 speed like the lexus .
I also see the power steering reservoir on the drivers side of youre intstall
the ls400 has the reservoir on the passanger attached to the pump what pump are you using.
Old 05-30-2009, 10:13 PM
  #52
toylocost's Avatar
your front driveshaft is gone... just so you know... lol
Old 05-31-2009, 06:25 AM
  #53
gennro's Avatar
The first relay from the right is the EFI relay, next is fuel pump and injector circuit relay and the thrid is the fan relays.
I'm using the sc400 PS pump and just ran a 3/4 hose to it for the supply and used the high pressure PS line from the SC400 for the feed to the PS box.
Old 05-31-2009, 10:12 AM
  #54
RMA
RMA's Avatar
Hey so your using the toyota truck fuel pump .I saw these and was wondering about that, looks like the single speed is easier to wire up (3 relays ) not 4 relays (dual speed).
Dual speed
single speed
Old 05-31-2009, 05:14 PM
  #55
Azca's Avatar
What do you think this will end up dollar wise? What was your biggest headache/headscratcher besides the ECU and cooling? Any surprises?
Old 05-31-2009, 06:00 PM
  #56
gennro's Avatar
I'm probably getting close to 3 grand for this swap so far. So far the biggest headache has been the ECU. Other then that its been a pretty straight forward swap. The best advice so far is defiantly having a donor car.
Old 05-31-2009, 11:38 PM
  #57
TNRabbit's Avatar
Dual speed
single speed
So what exactly was the purpose off the 2 speed fuel pump if it isn't necessary??
Old 06-01-2009, 02:28 AM
  #58
gennro's Avatar
From the FSM its to reduce the electrical load on the circuit by running the fuel pump in high only when needed.
Old 06-01-2009, 08:01 AM
  #59
RMA
RMA's Avatar
I read that the high speed was used only when cranking,starting the car . But yea some swaps use only one speed and are fine with it ... is what I have read.
Old 06-01-2009, 08:07 AM
  #60
gennro's Avatar
I believe that is kinda right, but the FPR does that at the time of starting to increase fuel pressurewhile the engine is hot. Mine is running just fine on the single speed. The transmission works and the transfer case does also. I also found the solution to replace the No. 1 and No. 2 Speed sensors from marlincrawler. http://www.marlincrawler.com/transfe...eed-sensor-mci This will hook right into where the speedo cable hooks up. This will fix the lack of the 4 pulse signal the computer needs to shift the transmission. Now this will make the speedo inop, but I also found another solution is a HUD displayed Speedometer GPS for only 88 bucks. http://www.expansys-usa.com/d.aspx?i=162308
Quick Reply: 88 Toyota 1UZ Swap plus MORE!!!!
