86 22re 5 SPD 4x4 to a 89 22 r 4 speed 2 WD just wanna swap motor will it work
Got an 89 2 WD 22r carbed. 4 SPD wanna put that engine in a 86 22 re 5 SPD 4x4 can I do it? What does it take? I'm a yota new bee. Will the tranny housing mount to the 22 r? Will I have to change flywheel? The 22 r has 78000 miles on it the 22 re efi has 230000. And this is why I'm changing out $$$$ issues.. Good motor in a 2 wheel. No good in a 4 x4. Am I at a loss or can I get out kinda cheap? I appreciate any help in this issue thanks.
Originally Posted by JokersDirtyRide
(Post 52302417)
Yes !!! you need to keep the flywheel and clutch from your 4x4
If you are keeping the Carb and not swapping over your EFI parts . You need to get a fuel pressure regulator to reduce the pressure from the Higher pressures needed for EFI. Other wise it will just push past the needle and seat and fill the cylinders with fuel. |
I believe the camshaft is different between the 2 motors . You will also need to add the fuel pump lobe to the end of the cam ,so the fuel pump will work. It just bolts in .
