3.0 to 22RE
3.0 to 22RE
I work on outboard motors not cars so this is a new project for me. I see people going bigger but not smaller. Have a 91 toyota pickup rv with a 3L v6 with low compression. Found a 22RE 4 cylinder motor only for dirt cheap. What frame modifications or parts would i need that arent going to be directly swappable? Mine is also an auto transmission, im not sire what the 22re is yet.
A long block 22re is the same for manual or automatic transmission. I don't know much about the 3vze but I know you'll definitely need a wiring harness and ecu. The entire intake and exhaust (at least up to the cat) would be different as well. Do you know if the engines share a flex plate and torque converter? You'll likely need a bunch of brackets and other parts to fit the 22re and have it work right so I hope you have an auto tranny 22re donor vehicle to work with.
4banginRunner
All Other Toyota Swaps
21
07-11-2011 03:50 AM
tlake
10-24-2006 06:49 PM
