YotaTech Forums
-   Solid Axle Swaps, All Years (https://www.yotatech.com/forums/f152/)
-   -   Wheel Studs don't work? (https://www.yotatech.com/forums/f152/wheel-studs-dont-work-270787/)
noble Jul 9, 2013 02:08 PM
SOLVED Wheel Studs don't work?
Hey All,
In the middle of rebuilding my axle, well almost done, and have run into a snag... The wheel studs were pressed out of the hub to remove the brake rotor, but don't seem to fit when the new rotor is sitting behind the hub, I can push them out with my finger, they don't appear to be long enough... Any thoughts? These are the original studs off the 85 axle.
Thanks in advance
noble Jul 9, 2013 02:35 PM
How the rotor fits on the back of the hub body with bolts installed and studs in, however they are just resting there
http://i1211.photobucket.com/albums/...one/photo9.jpg
This is me using my finger to push up on one of the studs... This definitely isn't right, any suggestions? These are the stock wheel studs.
http://i1211.photobucket.com/albums/...one/photo8.jpg
CJM Jul 9, 2013 03:22 PM
Cant reuse them, need new. They will be a bitach to put in too, press them in.
snobdds Jul 9, 2013 03:29 PM
Why did you take them out of the hub to begin with? New hub?
Xeo Jul 9, 2013 04:07 PM
I reused my studs and they were pretty tough to beat out and in but they do sit flush with the rotor, but by the looks of your studs your gonna need new ones.
Sent from my HTC Incredible S using YotaTech
noble Jul 9, 2013 05:22 PM
New rotors, late model solid axles have studs that need to be pressed out
SOLVED... Like an idiot and thinking these were not press on rotor hubs I pressed in the studs to the hub w/o the rotor on, which pressed them in too far and stretched the hub stud holes out big time... ahh the mistakes us homebrew SAS noobs make, live and learn, off to the junkyard
noble Jul 9, 2013 11:49 PM
Question in the same vein, will greasing the studs help w/ install? Whaling away on them with a brass drift and BFH doesn't seem to be having the desired effect
Xeo Jul 10, 2013 11:24 AM
Probably I didn't use any when I reused my studs, just a couple pieces of wood to keep the hub off the floor, a brass punch to smack in the studs and a mini sledge. I knew I should of taken pictures of how I did it.
