YotaTech Forums
-   Solid Axle Swaps, All Years (https://www.yotatech.com/forums/f152/)
-   -   Thinking about SAS (https://www.yotatech.com/forums/f152/thinking-about-sas-166547/)
king0581 Feb 9, 2009 05:48 PM
Thinking about SAS
I have a '94 ext cab yota with a 4banger. I also have a whole'84 yota setting in the junk that I was thinking of getting the axle from. I dont do any extreme wheeling so I dont need all the things like high steer and the beefier gussets. I;m just tired of wearing out idler arms and things. My question is will the pitman arm thats on my truck work? Also what about the driveshaft, will the one in my truck work or is the bolt pattern different. My plans were to buy the spring hanger kit from allpro (or the likes), and prbably just use the springs from under the '84 for now. I can fab my own shockmounts. I dont want to go much higher with the truck so I dont want the high steer kit. Any thoughts on this? Thanks
bigt Feb 9, 2009 06:08 PM
i was gonna kinda go the same route but i have decided to just lock my front for now.. i bet an ifs locked front will take me where i want to go.. im go to 63 in chebbys out back incase i do sas nextyear...
your drive shafts should work might need to be lengthed though...
yeah you can use the stock steering if you keep it low.
waskillywabbit Feb 9, 2009 06:12 PM
I think you are better off fixing your IFS.
:guitar:
Tofer Feb 9, 2009 06:22 PM
i'm not sure how you would use the stock steering (push/pull) with your IFS steering box.
bigt Feb 9, 2009 06:23 PM
yea im taking wabbits adice.. stick with the ifs till i can afford and NEED the ifs eliminator!!
you would be suprises the amount of people that sas a truck then run out of money and have to sell or take short cuts!
904_runner Feb 9, 2009 06:36 PM
Save the money you need for the sas/gears/lockers/tools/etc...
make a saving plan for said purchases. Do said project.
Then save up for the next mod.
For me its one project per paycheck or save money each check for a future project. and i still have money left over.
scuba Feb 9, 2009 10:39 PM
Feeris bueler your my hero...:dj:
king0581 Feb 10, 2009 02:10 AM
Thanks for the info folks. I already have 4.88's with a limited slip in the front. Like I said I dont want to go any higher with the truck and I see that in all these kits being sold they come with the high steer and I see that you have to add more lift to use it. Anybody know of anything else that can be done? I dont mind putting out the money for the parts. I was just wondering if among the parts I have for the steering, if they would work.
