Sas Qs
So it looks like i will have a budget to sas my 96 taco by the end of the year. Probably 3k but can maby pull some more if needed. That will need to cover the whole sas with tires and 35s and hopefully a elocker with regear. Hoping to run 35s so as low as possible with minimal cutting! So being new to yotas give me pointers. What all do i need? Best dd, minor freeway steering set up? I can weld and install everything. I want to look into chevy 63" leafs. Can i put them front and rear? And new springs will give how much lift? My ifs manual hubs will be useless to me aftd
After the sas? I need a lot of help! Its a 3rz 5 speed and i think it might have a tundra 3rd member out back. Can you swap from 4 cyl up in the same housing other then elocker?
Thats a lot of questions. Kind of hard to give pointers in that a lot of set ups are preference inspired. First of you will need more than 3 k. 2nd what is the end use for the vehicle? DD, trail rig, rock crawler etc.
Still in the process of finishing up a sas on my buddies 92 pickup and he's got nearly $5k into it and still not done yet.
| All times are GMT -8. The time now is 04:21 AM. |
