YotaTech Forums
-   Solid Axle Swaps, All Years (https://www.yotatech.com/forums/f152/)
-   -   Removing a leaf from the pack (https://www.yotatech.com/forums/f152/removing-leaf-pack-150670/)
John S. Jul 31, 2008 07:24 AM
1 Attachment(s)
Recently finished SAS on my 88 4runner and the front is a few inches higher than the rear. I have the trail gear 5'' hd springs in the front and 5'' in the rear, but it is no where level. I was just wandering if I removed a leaf from the front pack if it would drop the front enough? If so which one should I remove?
Attachment 70656
4Crawler Jul 31, 2008 08:26 AM
Might contact TG for advice, but generally pull the 2nd leaf from the bottom and see how it looks. Also, most folks gor with 1" lower spring up front since you get a built in 1" of lift due to the spring hanger and longer shackle on a SAS.
