what years, make, and models did the bolt on high pinion 3rd's come in?
im calling junkyards in my area and they need that info to look in there computer! any help would be great thanks! |
yea that info would help alot!!!! I have the same problem with only 3 inch springs in the front!!!
_______________________ 1986 toy standard cab strait axle, bobbed flatbed, 22r 5spd weber32/36 carb with knn ,warn 8000, 3" custom springs in the the front, 4" blocks in the rear. 12" Trail gear long spline fd shaft. 4.37 gear ratio. 37x12.50x15 IROKS 95 dodge 1500, 5.9L multi port fuel injection/ KNN..... 2" lift with 33x12.50x15 |
Originally Posted by TOYOTA 1
(Post 50774819)
Originally Posted by d0ubledown
(Post 50775461)
91-97 80 series. check with irbis offroad. they've got some 80's theyre parting out. also might want to check ih8mud's classifieds. there are also some 80's parting out there as well...
im pretty sure. the 60's have a different (bigger) front diff. the 70's also fit as blizzard shows..but i dont think you guys can get 70's down there?
they're available up here though. might want to look into some jdm import shops. try mustang.bc.ca or jdmparts.ca and various other jdm wreckers. you'll probably have better luck & prices searching for 80 series..and if youre lucky will score a locked one. |
Thanks doubledown ! ill start lookin for the 80 series ? DO u no how mush they usally run???
__________________ _______________________ 1986 toy standard cab strait axle, custom bobbed flatbed, Custom winch mount and bumper, 22r 5spd weber32/36 carb with k&N ,warn 8000, 3" custom springs in the the front, 4" blocks in the rear. 12" Trail gear long spline fd shaft. 4.37 gear ratio. 37x12.50x15 IROKS 95 dodge 1500, 5.9L multi port fuel injection/ KNN..... 2" lift with 33x12.50x15 |
